Yesterday I had to test out one of the cutters so I made a tool holder crafted after a CXA holder by Aloris.
The material I'm pretty sure was from a chunk of 4140 steel although I could be wrong on that. It certainly was
not mild steel and came from a tool and die plant. Although generally not too difficult to make one needs to
machine the last several thousandths in increments as the fit in the tool post is quite critical. I found it interesting
that once it was fitted to the Aloris tool post, it also fit nicely on my DTM tool post. I had to take my time with
threading the holes as it was a bit challenging. When all done, I clamped the cutter between two blocks
of hard wood and was pleasantly surprised that it came apart from the arbor fairly easily(metal to metal, no paper washer).
I may make another one and try the paper washer and see how that works.
It looks like I have enough material to make three more of these holders. I may heat this one up and quench it in oil and find
out of the stuff hardens.
