- May 2, 2015
- 112
Getting ready for the drive...
I spent a lot of time trying to "map" the bed rails so I had a base set of dimensions to go by in determining how thick a shim would need to be made for the gearbox, lead screw bearing support and rack gear. I did not want to use Moglice or Turcite. This turned out to be very important and saved me a lot of time. I used simple V blocks and measured to the underside of the rail. It gave me a baseline that ended up being incredibly close. I used a gauge pin that wass snug in the wiper screw hole on the saddle to get an idea of what that heights was and could compare it to when I got the saddle back. All these measurements when used in conjunction with the numbers from planing - I was within 1-2thou. of what the shim needed to be.
