[4]
Scored Punch Press
[3]
[10] Like what you see?
AGCB97
H-M Platinum Supporter ($50)
Apr 22, 2016
281
Got a mechanical punch press yesterday. No model number on machine but according to pictures on internet I think it is a Whitney Jensen 129, 10 ton. That also agrees with serial number which is 129596555.
I used a punch press one time when I was in high school (40+ years ago)when I took a short part time job. Other than that My experience and knowledge of them is nil. I never would have thought I needed one of these but because of the price ($100) and the uniqueness of having one, I succumbed. It appears to be in good condition and I've punched a couple of holes in 18 gauge steel with the 1 1/4" die set that is in it. The other plus is that it is 110 volt.
So, I'm looking for a little more info. I have a range of dies from 1/8-1 3/8 round, plus a 5/16 square and 1/8 x 3/8 oval. What can I expect as to thickness of mild steel and diameter that this will punch? Also I've looked at safety concerns on the web but what other than sticking my fingers under the punch could hurt me?
Aaron in Iron Mountain MI
brino
Jan 2, 2014
3,610
.....for $100 I would "succumb" too.
Great deal!
I guess some other dangers could be shattering dies if they are too hard, cracked, or misaligned(top and bottom).
-brino
Tony Pisano
Active Member
Nov 2, 2017
62
Nice score. You shouldn't have much problem using "bought" punches and dies. Never let safety leave your mind while using. I've seen guys forget to remove bars used to rotate the mechanism while setting up and starting the machine.Other things to keep in mind, which all seem like common sense are:
Be sure your punch and die are secure and perfectly lined up. If they are in a dieset, it's not an issue.
Don't go deeper with the punch than necessary to punch the hole.
Be sure to cycle your setup through be hand to make sure everything is in line and you have the proper depth set.
Absolutely make certain that there is clearance for the slugs that are being punched to drop out of the die.
Add a stripper plate to you setups to strip the punch from the material.
The material you can punch will depend a lot on the clearance you have in the punch and die. If I remember correctly, the Strippit press we had had 2 dies for each punch. One had .006 clearance for thinner material, and the other was .012 for thicker stock. You an look up reccommended clearances for the material you are punching and the hole diameter.
I still have a kick press, a foot operated punch press that can do some cool stuff.
Have fun, be inventive, and stay safe.
bhigdog
Active Member
Apr 29, 2018
139
Make no adjustments to the set up while machine is powered up. Do not get any body parts between die while machine is powered up. If it's not already, wire machine so two hands are required to actuate the ram.............Bob
Old Mud
Aug 8, 2016
113
I agree totally, for the price of the motor you have a very nice piece there.
benmychree
John York
Jun 7, 2013
3,442
I was taught that the die clearance should be 5% of the thickness of the material being punched (per side). For the average home shop, I cannot imagine a more worthless addition, so far as usefulness is concerned, no matter how cheap it might be; likely, it will just take up space, I speak from experience, I had a 12 ton Niagara once upon a time in my commercial shop, never found a use for it, finally traded it away to a machinery dealer.
bhigdog
Active Member
Apr 29, 2018
139
Sad to say but I have to agree. The 10 ton I had I traded even up for a Bader belt grinder. That was the most useful thing that press ever did for me................Bob
benmychree
John York
Jun 7, 2013
3,442
That was a fantastic deal, that belt grinder, wish I had one ---- ! I had a Square Wheel belt grinder at my shop, had to leave it behind when I sold the place; I can go there and use it if I need to.
AGCB97
Apr 22, 2016
281
Well, I hope to use it at least a $100 worth! It's not taking up room in my shop because I put it in the 'shop annex', which is a 10x30 roof overhang along side the shop. It's so much nicer to work outside, especially for grinding, cleaning and other dirty jobs.
It came with about 40 lbs. of dies and punches of at least 3 different sizes but only has a holder plate that fits 3 of them so that will be the 1st order of business.
From posts I received here and disassembly I've basically learned how to 'set up'.
Nice score.
Mind mentioning some of that 'cool stuff'?
Attached a few pics of install and annex.
Thanks for all replies!
Aaron
MrWhoopee
Brass
Jan 20, 2018
710
My very first job as an apprentice was running a 30 ton punch press, punching and shearing 1/8 x 1 HR flat for filter brackets. No guards, one hand actuation. I was really cranking out the parts when my JC machine shop instructor dropped in. Thought he was going to have a stroke.
Be VERY CAREFUL! They are very fast and couldn't care less whether it's steel, flesh or bone.
I'm with the others, I can't imagine what I would do with one.
AGCB97
Apr 22, 2016
281
No imagination! I feel sorry.
bhigdog
Active Member
Apr 29, 2018
139
I think what's being said is that a punch press is first and foremost a production machine designed to crank out thousands of identical parts. Once the initial tooling and set up is complete it will do this with astonishing efficiency. That said, the very first part produced could easily cost $10,000+in tooling.
In a non production shop there are usually far better ways of producing a limited number of parts than tooling up a punch press.
Your case may be different. Also, if you feel the fun factor of gaining knowledge and experience with it is what you are after I say good for you.
That was the experience with my punch press. It was great fun until I realized there really wasn't much it could do efficiently other than beat out thousands of the same doohickey or punch the same hole in a limited thickness of material.
Enjoy your machine. It was a good buy dollar wise........................Bob
Winegrower
H-M Supporter - Silver Member
Jul 29, 2014
272
I love the vise-grips on the webbing. Learned a new trick there. Nothing could go wrong with that! :)
Tony Pisano
Active Member
Nov 2, 2017
62
Aaron
If you are going to do some decorative work, like making metal strips with a series of holes or especially slots it's great. At one time, I made a punch and die to stamp out small spinner blades for fishing lures. It had the small round punch and the outside shape of the blade so after the initial hole, every kick produced a finished blade. You could set it up to rivet parts together. I made a punch and die to punch holes in aluminum tubing for making windchimes when I made dozens of sets. The holes were for rubber grommets that the hanging strings passed through. I do agree that a press is more for production, but having one, if it doesn't take up valuable real estate can inspire you to be creative. When I was making chimes, I also picked up a benchtop arbor press. I had been making the hex shaped tops of the chime sets out of ash and had to mark 5 or 6 double sets of holes for the hanging strings.I hade been using a template with holes and marking each hole with a pencil. With the arbor press, I made an aluminum plate, drilled and tapped holes in the proper places, then installed pointed transfer screws in each hole. With the plate mounted on the shaft and a positioning fixture on the table, I just had to set the wood tops against the stops and with one pull of the handle, all of my holes were marked. Aa a bonus, the marks were equivalent to center punch marks so the drill bit followed the exact positioning. At other times the arbor press doesn't get frequent use, but I wouldn't be without one when it comes time to replace a small bearing on a shaft or do other small jobs.
AGCB97
Apr 22, 2016
281
Thanks Tony, great ideas
Tony Pisano
Active Member
Nov 2, 2017
62
All of the presses in our shop were pedal, dog actuated. They ranged from 10 ton to 50 ton presses. Your hands had free range to be where you put them. You learned to be sure they were in a safe place before operating the pedal.
KBeitz
Apr 17, 2018
478
I made a shear using two old files. It sure is fast for shearing small parts. I make yarn racks
and i shear 1/2" cold roll round all day.
RJSakowski
Feb 1, 2015
4,042
I have had a 30 ton press and a 1 ton press for more than 30 years and have never used them once. I had a manufacturing business and made my own electronics enclosures and the idea of punching the blanks seemed good at the time. The problem is that a large amount of time must be invested in making a complex set of dies and unless you're looking at hundreds to thousands of parts, the payback is low. I was making about fifty enclosures a year. The last work the 30t press did was punching out paper washers for dry cells at Ray O Vac. Talk about overkill!
A inertial punch press works best in an automated fashion. Single stepping would normally be used for setup purposes.
I have a kick press that I made some simple dies for which I used for almost 20 years. I had three sets of dies set up on a single plate and pins for alignment of the punches and dies so setup was fairly simple but even so, I still tried to run a dozen pieces with each setup.
Another issue with using a press is alignment of work. For one-off usage, this could be a real concern. I used guide pins for my applications but this required prior machine work.
Unless you are in production, a CNC plasma deck would be far more versatile. Safer too. A good friend of my father had only a thumb and little finger on his right hand an arc in between thanks to a punch press at Sunbeam Corp. It ended his working career and put him on disability for the rest of his life.
I still have all of of my presses, gathering dust, rust and cobwebs in my barn.
vocatexas
Active Member
May 8, 2017
191
A friend of mine has three punch presses for sale. I think one is a 50 or 70 ton. I can think of a couple of projects they might be useful for, but I'm not sure they're worth the time and effort to move and set up.
KBeitz
Apr 17, 2018
478
First picture is my lower plate holding my file shear.
AGCB97
Apr 22, 2016
281
I'm not quite sure I understand your pictures. Could the 1st and second be reversed? Is this an anvil type shear as opposed to a bypass shear?
Thanks
Aaron
KBeitz
Apr 17, 2018
478
Your right... Some how the pictures got swapped... Yes it is a anvil type shear .
Tony Pisano
Active Member
Nov 2, 2017
62
Just noticed photos. Did you have to temper the file?
KBeitz
Apr 17, 2018
478
I only ground an edge on it... I'm surprised the hammering that it takes without breaking.
[5] [7]
