- Jun 12, 2014
- 4,817
FYI, the use of detergent oil appears to have been suggested for total loss oiling systems where it is felt that the detergent oil might be more effective in flushing out impurities and varnishes, but I did not see any recommendations for use in recirculating oil systems (that do not use filters). The oils these days are much better than what was available in years past, and for a low speed lathe I think having the proper viscosity for the operating temperature is the most important factor. Often with a 30W engine oil when used in a lathe, it proves too viscous and the bearing will heat up. Engine oils are designed for much higher operating temperatures for their rated viscosity, vs. gearbox circulating oils and hydraulic oils. Synthetic oils can be a problem with older seals and will often leak more, I have used synthetic oils in a high speed mill head and did increase the top RPM and the bearing ran significantly cooler, but in my gear head lathe I use ISO68 circulating oil rated for both gears and hydraulic systems. Wearing out the oil/failure is not an issue as opposed to moisture contamination over time, thus changing the oil annually. I think this may be a contributing factor to the smell as well as the oil degrading with time gets that gym/bathroom smelly stench.
There is no reason for this to be any argument..
Re: Lubricants to use on the moving parts of a lathe????
I don't dispute the information of this thread. Mr. Knox wouldn't be a guru if this wasn't taken out of context. We have learned here that it is a "total loss" type lubrication. I would think this is but a step to flood out impurities and Then the proper non-detergent be used. Heck, folks would use a mix of kerosene in engines for a bit, just to get the gunk out.There is no reason for this to be any argument..
