- May 16, 2016
- 1,698
My primary work is done at a maker space (Techshop). Finding a sharp drill bit is a constant source of frustration. I'd like to invest in a quality set of bits (standard size) and a bit sharpening tool. I am primarily working in aluminum and steel. Would appreciate any recommendations, since there are so many options.
Thanks
Jim
It appears there are two schools of thought here, 1. go cheap and top up as needed. or 2. go the whole hog and hang the expense.
While we don't have harbor freight here in down under. I gather they are similar to the big box junk hardware shops we do have.
Unless you have money to burn, I would suggest buy a basic set of drills 118 deg standard or split points. you will find that a few sizes will be used almost all the time, certainly replace them with high quality bits as needed. There will be some sizes in the set that will almost never be used, and will probably never need to be sharpened.
I assume you are not an expert at sharpening drills, then certainly go ahead and buy a drill doctor, they are as good as any. the real trick is to make sure the drill is set up in the holder correctly, and unsure you make an even number of rotations.
I finally succumbed and bout one recently as my eye sight is not as good as it once was. I was taught as an apprentice some nearly 60 years ago how to sharpen a drill properly, and have always sharpened them by hand, but I now have problems with the smaller ones, so now with my near new drill doctor I'm back in business. I still do the bigger ones by hand, especially over 1/2 inch as I only bought the 500 model.
I also recommend you learn to sharpen drills by hand it can be useful when you haven't got the drill doctor with you, I would never take one to a tech-shop, nor would I take an expensive set of drill bits or any other special tools. There will always be some who will want to borrow them , and not respect them.
