Shop-made Ball Turner - with a Question
If you can't drill it with a cobalt bit, then you are most likely not going to be able to tap it.
I built a similar turner and just adjust it from one side, a bit inconvenient but it works.
  • Like
Reactions: tjb
Carbide may drill it, but you still could not tap it; one possibility would be to partially anneal that section of the screw.
Nice job Terry,
I put my knob adjustment on the other side, cut a hex key at the end of my knob and retained with a small screw. Will pull mine out and see about the other side. I went with a CCGT32.52 so I could get a sharp edge, others grind HSS or use small round inserts.
  • Like
Reactions: tjb
Rotate the cutter to be below the workpiece and reverse the spindle rotation.
Be careful if you're using a screw on chuck.
  • Like
Reactions: tjb
Unfortunately, I think you're right.
Wonder how Ade did it?
Now, that's a thought. Thanks.
Nice job Terry,
Characteristically beautiful work, Mark. Do have pix from other angles?
I used an El Cheapo boring bar insert just to try out the tool. It performed very nicely. I have round inserts on the way and will try those out. I suspect I'll be okay with those, but if not, I may end up doing what you did.
Regards,
Terry
Ade didn't have a Criterion boring head
Oh! Well that solves the mystery! His looks nearly identical to mine, and I jumped to the conclusion that it was a Criterion. I went back and listened a little more carefully, and I don't think he ever identifies the brand of his boring head.
Good catch, and thanks for clearing that up.
Plan C, here we come.
Regards
