Can you get photos?Speaking of vices... a friend of mine had a great idea. He mounted a receiver hitch tube under his work bench and mounted the vice on a tube that slips into the hitch tube. The fixed tube has a nut welded on the bottom of the tube and a largish "wing nut" to tighten it down. He can rotate the vice in 4 different positions and slide it in handout a bit. It is great for welding- especially with the swivel base. He also has a bench grinder that he can slip in so his bench top is not cluttered with tools.
On the opposite wall he fabbed up a folding bracket for a vice which keeps usable floor space high. Not a very heavy duty rig to be sure but for some lighter work- hacksawing or drilling or grinding it works a treat.
