- Jun 10, 2019
- 534
So, its my first time having to make some NPT threads (1/8" and 1/4" NPT) to make an air distribution block. I found that the taps required a significant amount of depth in order to allow the fitting to thread in with enough engagement. For example, the 1/4" NPT tap required a 3/4" deep hole. In most fittings and fixtures (like air regulators) that I have seen, the 1/4" NPT threads only seem to run in about 1/2" deep. In my application: I need to keep the threaded depth to about 1/2"
The NPT taps I have seem to need to be threaded in about 3-4 threads shy of the full tap in order for the part to install at a normal depth/thread engagement.
I was planning on removing about 3-4 threads from the end of the tap (and yes: I would add a starting taper to the first 2-3 courses). I just wanted to see if my experience with NPT tapping depth is normal and if I'm going to be creating any issues by shortening the tap.
