- Apr 30, 2015
- 11,377
I wonder if he got a warranty with that?
MS
MS
I have the Everlast 255 EXT, really like it. I am practicing stick welding to get better. My TIG welding is fairly good now.How do you guys like those everlast welders? Especially the powerpro TIG/Stick/Plasma? That welder has been on my wish list for 2yrs or so.
No eye protection...particle or UV, no gloves and skin protection. Electrical is very dangerous. The welds look very substandard...so hopefully not a load bearing structure...though it looks to be perhaps scaffolding.My mind completes the picture. No goggles or any type of eye protection, and the other end of the line is connected with battery clamps to the service side of the the power line.
As for buzz, I can picture that thing walking around by itself.
I have also built a microwave-oven transformer based spot welder.
It does not get used regularly and was in the shed....the reason for the condensation rust.
I have another transformer that I can add in parallel to get more current.
The tips are used-up MIG contacts.
-brino
I will not go on the eternal public record of the internet and say that "there is NO risk it could explode from rapid discharge," However, I would be very surprised and confused if I saw a capacitor explode from rapid discharge. When capacitors explode, it's usually because they started leaking electrons through the dielectric, either because they are old or because higher than rated voltage was applied to them.I thought about using a capacitor with a diode in addition. Is there any risk it could explode from the rapid discharge? Where could that be found?
R
