Single Point Threading on a PM-1030V?
erikmannie
H-M Platinum Supporter
Sep 8, 2019
4,392
I had hoped to do better than a thread title with a question mark in it! That means that I haven’t figured this out yet.
I definitely know how to do single point threading on a lathe. At school, we had the big domestic machines where you used the TPI chart in order to find out where to put the levers to set the TPI.
The 1030V has a chart on it which I do not yet understand even though I have read the manual twice.
To me, the question was which change gears (if I am using that term correctly) came installed in the machine. I figured that out by physically looking at the gears when I had the door open to change from low to high range.
I am on my phone now, but I will get on a laptop and upload the chart when I get on a PC.
My main question is why they have an “H” listed next to the bottom (largest) gear. This is why I put the lathe into the high range, but this did not change the thread pitches that I was cutting. Also, as you know, the spindle RPM did not change the thread pitch.
My plan today (which was not a success) was to use the A, B and C speeds (the knob on the headstock) to see what TPI that I would cut. The A and C choices cut threads with TPIs that were in excess of 100 TPI, so I don’t know what went wrong there.
The B selection (which rotates the leadscrew the fastest cut either 32 or 36 TPI (I don’t remember), but that TPI value did not correspond to anything in a B row in the chart.
I found it interesting that the spindle speed had no effect on the TPI. So I guess I shouldn’t have been surprised that putting into high range still resulted in the 32 (or 36?) TPI mentioned above.
So hopefully somebody can give me a clue about how to proceed. I am going to go back and read the manual yet again.
This is the chart that I have yet to understand:
Have got the manual off of P-M's site, now,
Step 1: post up a picture of the chart(s) off of your machine.
*EDIT* NVM.... (hehe)
Posting more pictures now...
I wonder what this is a picture of. Is that a tool bit cutting a 45 degree chamfer? I imagine that it is a reference to the power feed speed for the carriage and cross slide. What are the black ovals supposed to represent?
One shows you the speed while feeding with the saddle - left to right
The other is while facing with the cross slide - in and out.
At least that's my interpretation of them.
Jump into the chat room.
Here are some pictures of the fun. If at all possible, I turn between centers for the historical experience..
And more pictures which are self explanatory:
I would change your set-up a bit , and this is only my opinion not knowing what lathe you're using . I myself would keep your tailstock quill in as far as possible , and have my tool hang out a little for clearance . That overhang in the tailstock will introduce chatter and possibly even a tapered part . A cnc reduced center would buy you some tool clearance . This is only my opinion , take it with a grain of salt .:)
