- Nov 7, 2019
- 436
Hello everyone!
I have a small bandsaw that I would really like, if it wasn't for the fact that it frequently throws the blade and the blades break really fast.
Generally either losing teeth or snapping at the welds or both in that order.
(Pretty much this machine but from another brand)
It's a small bandsaw that just sits on a table, the blades are 1435 x 12.5 x 0.65 mm if I remember correctly.
I've tried:
-Different blade tensions. Can't tell any difference here besides that high tension seems to help the blade track better.
-Different blades(big and small teeths etc). Big teeth will strip if I'm cutting narrow stock which is normal I think, but even the high TPI blades last a surprisingly short time no matter what I'm cutting.
-With lube/without lube. No lube seems to wear the blade faster and with lube seems to clog the drive system up, making it throw the blade...
-More/less down pressure when cutting. Longest durability seems to be with almost 0 down pressure, but also makes the cut take forever.
With a new blade I'll get maybe an hour of good cutting and then it's gonna start getting choppy(because missing teeth or similar).
This is when it starts throwing the blade of the wheels (which is a PITA to get back) and eventually the weld breaks and I have a $30 blade that's just scrap..
Any recommendations or tips on what to do to make this work better, would be greatly appreciated!
I've tried:
