Homebrewed:
After reading and re-reading your article, I am more convinced this simple tool can be built to suite the requirements of most Mini-Mills. Specifically the LMS 3960 or similar units. a single R8 Arbor can be used to hold different sized versions of this cutter.
The unique properties I envision is that of a small "Fleet" of Fly Wheel based cutters using the tool bit of choice in a Fly-Wheel of sorts to provide the diameter of the cut required. One Arbor forms the basis for the tool and different diameter Fly-Wheels using the available tool bit. This reduces the storage issues as only the Fly-Wheels of the differing Diameters are required to be stored.
As you have already stated the sharpening is simple and one Tool Bit can be used in all the differing sizes of the Fly-Wheels.
Many of us have our Work Shops like Harry Potter under the stairs or some other impossibly small location so any and all space is at a premium.
I have even given thoughts to a single large Fly-Wheel with the appropriate holes drilled according the the required radius of the cut required. The holes would have to be spaced about the Fly-Wheel so as not to weaken the structure or upset the balance of the Fly-Wheel.
Note: The Fly-Wheel now has to be designed as an integral part of the spinning cutter.
Home-brewed, you have spawned a monster that may go viral. ha ha
Again Thanks for Listening
