[4]
Snap Ring Pliers (On the right path?)
[3]
[10] Like what you see?
The_Apprentice
H-M Supporter - Gold Member
Staff member
Jun 14, 2017
248
Likes
128
#1
So, I've made a number of jump-rings for my girlfriend to use on one of her projects. They are 1/8" inch stainless steel, with a little over 1.5" diameter.
She needs to slightly open the rings a little bit in order to snap them into places. The problem is there doesn't seem to be jewelry stores that sell tools for something this big. I have been looking around and the closest thing I can find that maybe can fit the job are reversible Snap Ring Pliers.
There are a few issues with them though.
  • Most can't be used for rings that need to expand up to 1.5" or more.
  • A lot of the tips won't hold up against strong pressure
  • Making sure her hands don't get sore trying to get leverage
I am curious if we are on the right track here though, or if there is some other tool under a different name that would fit the project much better.
If worse comes to worse, I can try to just invent my own method and perhaps use some round-bar with a pin in my Mill to make our own plier-type tool. But that would take some time and experimentation...
David S
Nov 18, 2012
1,296
Likes
1,041
#3
Hi,
The snap rings I am familiar with aren't spread open like external c-clips but rather grasped with two pliers one on either side of the gap and twisted sideways to provide an opening.
Are these some how different?
David
francist
Sep 5, 2013
1,120
Likes
1,747
#4
There is a tool called a link spreader, I believe, that electricians use for chandelier chains. I've had it used twice when we were taking down very heavy chrystal chandeliers. Not all electricians have them, most favour the "twist from opposite sides" method mentioned above, as do I. But it is out there.
-frank
kd4gij
Feb 7, 2011
4,677
Likes
1,850
#5
Don't think a link spreader will work but the ones in post 2 should work unless the op is talking about a chain
F
f350ca
Guest - Please Register!
#6
Tire chain pliers might work.
Greg
dlane
Sep 27, 2014
3,042
Likes
1,452
#7
1.5” Id or od ? Stretching a 0 shouldn’t be a problem :rolleyes:,
The_Apprentice
Staff member
Jun 14, 2017
248
Likes
128
#8
FLguy
Jan 11, 2016
256
Likes
140
#9
The Princess auto looks to be a quality tool.
Bob Korves
H-M Platinum Supporter ($50)
Jul 2, 2014
6,068
Likes
6,394
#10
Don't count on it. Some of the Chinese made ones look really nice until the handles bend, the snap ring warps, and the plier tips break off the first time you use them. Snap ring pliers are a good place to splurge a bit for quality tools.
FLguy
Jan 11, 2016
256
Likes
140
#11
Pictures can lie. Hands on inspection, most likely not.
Dave Smith
Mar 10, 2013
1,077
Likes
243
#12
if you can find a spreader jaw for an old Eifel geared plierench it would work very good and it is adjustable ----it is geared so your wife could easily squeeze it----another tool that could maybe be modified to work good is a piston ring spreader tool---Dave
David S
Nov 18, 2012
1,296
Likes
1,041
#13
1.5" inner diameter. I'd like to expand even larger.
I found something at Home Depot (Atron Chain Pliers) but no hard stats given. I may ask them to take a look at it and see if it's something I could use.
https://www.homedepot.ca/en/home/p.chain-pliers.1000655652.html
Or, I'll simply drop by Princess Auto and do a modification to this tool:
https://www.princessauto.com/en/detail/4-in-1-interchangeable-snap-ring-plier-set/A-p8007417e
I am still trying to understand your application. Normally I twist jump rings sideways with two pliers to open and then twist back to close. Often depending on material if I spread them and then try to close, due to the spring back they won't close tightly. Are you going to have to close them tightly after you are done?
David
D
Deleted member 43972
#14
You mentioned these. I've used these LOTS as an electrician installing the custom lights in a house. I have two paires. They are not difficult to use. Little tricky to get oriented at first if you've never used them before, but it gets easier. I'm a big guy with strong manly hands, but I wouldn't imagine getting sore or tired would be much of an issue unless she's doing hundreds of rings, in which case, not really anything short of automation is going to solve that.
The_Apprentice
Staff member
Jun 14, 2017
248
Likes
128
#15
Kukshawn, I grabbed a pair at Home Depot yesterday and she gave them a try. It was just a tad undersized, but using a special TRICK she got it to work fine so it looks like we are all good for now (finally).
D
#16
I realized after I posted you were looking for something capable of 1.5” and those spreaders would be tight.
I’m glad you got it worked out.
EmilioG
Jul 20, 2014
1,349
Likes
576
#17
Knipex makes great pliers. All type of Snap RIng and circlip. Hardened Crv steel. Made in Germany.
brino
Jan 2, 2014
3,462
Likes
3,488
#18
....one thing NOT mentioned above: Safety.
I don't know about "jump rings" in particular, but I know many other types of snap rings can fire off in random directions with surprising speed and energy. All it takes is for the snap ring to slip off the pliers and zzzzing!
So get her a pair of safety glasses too!
-brino
KBeitz
Apr 17, 2018
439
Likes
228
#20
Link-belt pliers...
4cyclic
Sep 8, 2016
22
Likes
13
#21
Knipex on Amazon. Many sizes available.
bfd
Staff member
Sep 9, 2016
425
Likes
245
#22
maybe a piston ring expander tool would work? or maybe I don't understand the idea. bill
The_Apprentice
Staff member
Jun 14, 2017
248
Likes
128
#23
No kidding. I used a snap-ring to get a small c-clamp off part of my mini-mill a couple weeks ago. The damn thing shot off like a bullet ricocheting all over the basement. I was of course, wearing my eye-glasses. I always wear them any time I am working with anything under any kind of force/stress. I've learned lessons from observing my own father's eye injuries in the shop.
Silverbullet
Gold
May 4, 2015
3,420
Likes
1,675
#24
How about a piston ring installer for small engines ??
[6]
[5] [7]
