For the bench, a Weller WES51 has served me well for many years.
After using a temperature-regulated iron, I don't think I could ever go back to using a "dumb" iron. They warm-up much faster and also supply the correct amount of heat when you need it. I've done a lot of RC stuff in the past with those thick battery wires and it's so much easy to solder when the iron actively maintains it's temperature instead of cooling down when you touch the wire/connector.
