Over 20 years old the sales guy for The Fastener Center was flogging these. Worked fairly well, the techs (mechanics) found that a times like mentioned, not enough solder to completely fuse the joint. I tried a different companies terminal version recently, fail. No where near enough solder, and the metal rings, etc are so soft that you can almost tear them off with your teeth. I have reverted back to slipping on a shrink tube, solder the joint and then slide the tube over and heat it.
Pierre
