Can anyone recommend a source for a decent quality 4" 3-jaw self-centering (scroll) chuck that is ideally around $100.
I'll be mating it to a 4 inch 2-1/4"/8 threaded backplate adapter that I already have.
The chuck that originally came with the lathe as new was a 4" Bison but it was missing on mine and a new Bison would be 2x what I paid for the lathe. I'm reluctant to buy used off eBay due to wear issues. No luck looking locally on CL.
I've had to return one Chinese chuck already, the machining on the jaws was awful.
I've had fairly good luck with Shars in the past and the description on this sounds encouraging
4" 3 jaw Self Centering Scroll Lathe Chucks Solid Jaws
www.shars.com
- Each chuck has gone through rigorous accuracy and repeatability inspection by clamping and jamming multiple random testing rods or rings
- Accuracy is maintained for the entire clamping range
- A serialized set of jaws are then finished, ground, and lapped on their designated chuck body which will be the same chuck body on the final assembly to achieve a greater accuracy
- Before assembling the jaws to its designated chuck body, the jaws finish machining is performed on a close tolerance state of the art CNC machine from Japan
