I got my first lathe free from work as it had been damaged by being turned over during moving. It was placed in storage and I talked them out of it.
It is a 1943 South Bend 16" x 6' lathe.
I finally got it home about a month ago and this is what was visible:
Carriage handwheel broken off
Cross feed screw was broken off behind the handle
Compound handle was bent
Belt tension lever broken off
Single tumbler bent so the pin won't pull out
QC gear box lever (Left/Right) broken off
Cone cover broken
I was fortunate to find Old Iron on the forum and made arrangements to go see him in Alabama.
He was gracious enough to donate some of the parts I needed:
Belt tension lever
QC gear box lever
Tumbler with pin assembly
Spare motor as I was not sure what was in the lathe
Other goodies I sincerely appreciate.
Here's where my son and I are now.
We have removed the cross feed screw and it will have to be replaced.
We struggled with the tapered pin on the hand wheel until we gave up because we were scared we would break the apron housing. We made sure we were hitting the right end of the pin.
We finally got the tapered pin out of the tension lever.
We removed the old motor and it is a old G.E. 2 HP 220v/440v 3 phase. I took it to work and have a friend hooking up an Allen Bradley VFD with remote F/R/S switch along with a speed control and E stop. This should be ready Friday. Again, no charge.
Now, the bad news. When we were getting the motor out we noticed that the countershaft cradle was broken in two pieces. We got the tension mechanism out and are working on driving the shaft that the cradle pivots on out. We beat on it trying to move it from left to right and it wouldn't budge.
We tried the other side and was able to move it past the first hinge and that is it. I'm guessing it is in a bind. We have tried jacks to keep it in place but it hasn't moved any further. Once we get it out we will weld it unless someone knows where to get one.
Any suggestions on what to do?
I have contacted Joe at Plaza Machinery and he is looking for the crossfeed screw and some other items.
I'll try to get some photos of the progress this weekend. Sunday I have to leave for Bankok Thailand for 3 weeks and it'll be awhile before we get back to it.
Thanks for any help,
Rp
Cone cover broken
Belt tension lever
QC gear box lever
Rp
