- Jan 12, 2021
- 14
Thanks for all the replies. The metric pipe thread is on a pipe and cap that serve as an oil drain line on a diesel MultiQuip trailer mounted genset. I have always been nervous about the cap vibrating off and draining all the oil from the crankcase. I was intending to get a 90 degree elbow for the pipe with one end this metric thread and the other standard NTP. Then I can add a valve, more pipe and then a cap. I need more pipe since when the oil drains out is pours over the axle fender and makes a mess. I am still attempting to get the thread specifications from the manufacturer MultiQuip. Since this unit was manufactured in 1990 it's been an uphill battle. I may take advantage of an offer to upgrade my unit to another used unit. Higher output, but it has more hours on it. 4200 hours is not bad for these diesels. The cap might even be a proprietary thread specification. The engine is an Isuzu 4 cylinder diesel. I have not determined the country of origin for the trailer.
The photos show the close up and farther back picture of the cap, then the pipe going from the oil pan to the opening.
