- May 4, 2015
- 3,583
You could wrap it in aluminum foil and heat it in the oven.
What was the cost?I had the same problem with mine. I sent it to Precision Instrument Correction.
Precision Instrument Correction, Inc. | Calibration Services | Brea, CA
Precision Instrument Correction Inc. is an ISO/IEC 17025:2005 Accredited Calibration Lab. PIC has been providing quality calibration services in Southern California since 1982. We offer one-week turnaround, expedite, and onsite service. Call our sales department at 714-671-6018 for more detail.www.picinc.net
They fixed it and calibrated it.
IIRC, it was about $95What was the cost?
have a 224 n which does not ratchet, rendering it useless, spindle is free, any ideas pleaseI found what I thought was a great deal on a little used Starrett T230RL 1" micrometer. It had some old gunk on it, so I thought that was why the spindle was sticky when turned. I took the spindle out, cleaned and degreased everything, and it is still so tight I can't use the ratchet.
Upon looking at it, it appears the spindle lock mechanism isn't retracting enough and is dragging on the spindle. It will turn to a stop and lock the spindle, but it will spin all the way around the other way and release a bit, but not enough for the mic to spin freely. I found a bit of info on line, and several mentioned that, when the thing is apart, DON'T turn the spindle lock. I'm sure I did when cleaning it. Nothing I can find mentioned how to fix this issue.
It may be related, but it's off zero by about .0005, and I tried to rotate the barrel with the spanner, and it won't budge. Thanks for any advice!
have a 242 in mic. staratt, excelent cond. but will not ratchet, anf ideas would be very welcome, ive taken the screw out from the knurled thumb piece and tipped wd40 in, no differenceI found what I thought was a great deal on a little used Starrett T230RL 1" micrometer. It had some old gunk on it, so I thought that was why the spindle was sticky when turned. I took the spindle out, cleaned and degreased everything, and it is still so tight I can't use the ratchet.
thanks, whole ratcheting assy was 12 usa, they are sending it for freeMy original answer disappeared.
https://www.starrett.com/spare-part...=list-condensed&itemsPerPage=24&sortBy=wp/asc for Starrett USA for parts or Amazon.com Starrett can get the part number for your micrometer 242. phone (978) 249-3551 https://www.starrett.com/about/contact-us
Go on a free site or ebay to get part number of the ratchet and then look for other micrometer models that uses the same ratchet. I suspect that Starrett uses are only a few different ratchets (most use the same one $12).
Find a bent caliper from a garage sale for near free to ebay for a few dollars. My free micrometer was perfect except the spindle didn't rotate at all. I cut out a spring from a broken self grounding electrical outlet, then bent it to fit. You might get the spring and ratchet for near free.
