Steel for cross slide feed screw
TheArkBuilder
Jul 17, 2023
16
I've be looking for material to replace the cross slide feed screw on my lathe. The main steel I'm considering is 1144 but want to see what though lts people had
Thanks
Seth K.
Typically I buy acme rod from mcmaster Carr and either machine the journals on or bore and drill and taper pin the assembly together.
They have left hand as well as right hand in two grades.
1144 would be an excellent choice, good strength and machinability. What size thread is it? A small diameter Acme thread is a challenge to machine, you will probably need a follower rest to control deflection.
You might want to consider a steel with some lead in it, like 12L14.
That is a good Idea, although I was just looking and I need 7/16ths and they don't have it I may look around at other suppliers
It's 7/16ths in diameter and about 8 inches of thread
Use Stressproof, it does not move around when cutting deep coarse threads.
