- Apr 14, 2012
- 78
I have a Chinese lathe/mill combo (Jet 8X18) made in the 1980s. It calls for capacitors in the start switch system for both of the single phase motors. For the lathe, it calls for capacitance of 25 mf for 110V and 12mf for 220V. The capacitor that was in the lathe circuit when I got it look like the original (due to the hook up) and was rated 20mf and W.V. 250 VAC. First of all, would a 250V capaitor work if the lathe is hooked up 110V? Secondly, this is more mf (20 vs 12) than specified. Is it OK to have more mf just not less? Thirdly, no where in the specifications does the mfg. state whether the capacitors are start, run, or start/run. Which type would be appropriate in this situation? Thanks for any input. Jim
