Yes, I have one. Good for fine adjustments. The only problem that I see with mine is that if the tailstock stock center is offset by more than a couple of degrees, then the conical surface of the center’s contact area is in effect an ellipse and can cause runout. If you cut a tube at 90 degrees to the bore, you have a circle. If you cut a tube at 87 degrees to the bore, you have an ellipse, (measured diametrically). Same thing applies to offsetting the tailstock a lot.
