- Jun 6, 2014
- 183
Hello all, thank you for taking the time to read my post.
I am looking to put together a "temporary" drive for my milling machine to make it usable for the short term. In the future I plan to build a much better drive with a high/medium/low ratio and a 3 phase motor with a vfd, however that will not be for a while as my wife and I are expecting our first child in about 6 weeks. Once our son comes I expect I will have a lot less time, energy, and money to expend on hobbies for a while so I would like to be able to at least use my mill when I have time to tinker, even if things are not ideal.
I have a Vernon 0 horizontal mill with this porter cable vertical head and a 3/4hp 1725 rpm single phase motor. My plan is to build a clamp on motor mount with a fixed ratio chain drive. If I use a ratio of 1.25:1 then a 1/4" endmill will give me 92 sfpm and a 7/16" endmill will give me 160 sfpm. My thought is that I could mainly use the small endmill for mild steel and brass/bronze and the larger end mill for aluminum. While far from desirable, does anyone see a real problem with doing this? I don't really mind having to slow my feed to compensate for fixed spindle speed for now, and I am not doing a lot of milling and it is strictly for fun so no need to rush.
