[4]
Touch DRO on PM-25, or..??
[3]
[10] Like what you see?
Dawn
Active Member
Jun 4, 2018
37
Looking around at different DRO's I am kind of liking the Touch DRO system. Does anyone have this on their mills here?
Or, there are some rather inexpensive options listed on ebay. What are your opinions and experiences?
Thanks!
coherent
Active Member
Aug 6, 2013
228
My mill is cnc so no experience installing DRO's on my mill, but I wanted some on my lathe and didn't want to spend a lot because I wasn't sure I really needed them on the lathe. Still don't know that I "need" them but they are handy and simplify a few things. Bought some of the inexpensive iGaging DRO's off Amazon. Mounting wasn't too bad and they seem to be accurate, repeatable and I've had no issues so far. I've no complaints considering the price.
ttabbal
H-M Supporter - Silver Member
Jun 12, 2017
798
I bought my DROs from 88490755 on ebay. They are the more typical style. I looked at Touch DRO a lot, but with the pricing on the Chinese units it's tough to go that route. I figure the glass scales aren't likely to have issues, and they should be able to be modified to work with Touch DRO later if I have problems with the display units. One thing that led me this way was that longer igauging scales get less accurate over their length. The short ones are fine, but longer units have more error. Glass scales don't do that. For the price of a set of igauging scales on ebay, I could buy the full DRO kit, and there are a lot of reviews here saying they like the Chinese DROs. There are a lot of sellers offering them.
On the down side, the instructions are written in the finest Chinglish which makes them somewhat difficult to use. That said, it's better than my Chinese, so I guess they win there. They all seem to be made by the same couple places though, so I suspect I can get help with them from the forum here and via YouTube etc..
I should also mention that I haven't installed them yet. That's hopefully soon. Some quick testing shows them working well. I just need to finish up some existing projects before I can get them installed.
7milesup
H-M Supporter - Gold Member
Jan 7, 2016
349
You can look through this guys store. A number of H-M members have purchased from him with seemingly good results. I was going to pull the trigger on one but then summer came and my part time job went to zero time, so maybe next fall...
Ali Express Siton Store
Dawn
Active Member
Jun 4, 2018
37
...the instructions are written in the finest Chinglish which makes them somewhat difficult to use. That said, it's better than my Chinese, so I guess they win there.
Hahahaa! Mine's not so good either....:grin big:
wrmiller
Chief Tinkerer
Mar 21, 2013
3,440
I used the smaller scales on my PM25 (G30?) and those worked well. The regular sized scales might me a problem, I'm not sure though. Might want to do some research on this, and hopefully others here will chime in on this as well. :)
Dawn
Active Member
Jun 4, 2018
37
Hi,
"Smaller scales"....? Was this on the Touch DRO system or the ebay complete units? Thanks!
wrmiller
Chief Tinkerer
Mar 21, 2013
3,440
Mine was a different vendor/system (DroPros), but the scale size (G30) is a fairly common offering that is a smaller scale than the full-sized ones and should be offered by many DRO vendors. This is a semi-educated guess on my part, but really all you have to do is contact the DRO vendor and ask them if they offer the smaller G30 glass scale.
Hope this helps. :)
Kiwi Canuck
Oct 27, 2016
224
Dawn, I purchased from the Ali Express vendor above (Siton) and was satisfied with the initial transaction and the pricing was excellent, but I ordered one of the scales incorrectly, totally my fault.
Exchanging the product was difficult and time consuming, so make sure you are sure about your order before hitting the buy button if you do buy from China.
I bought Easson ES-8A, 2 Axis for my lathe and a 3 Axis for my mill, the Easson product is excellent and I love mine.
When ordering the scales you need to know , three things.
Length of scales (versus table travel)
Resolution of the scale, 005mm or 001mm
Size of the scale, Standard and Mini, Easson has 2 sizes, GS10 (GS11) is about 33mm tall, GS30 (GS31) is about 26mm tall.
I learned a lot from these 2 sources.
DRO Pros Videos.
http://www.dropros.com/DRO_PROS_Digital_Readout_Videos.htm
Youtube,
This one almost needs subtitles.
This one is a very nice install. (just don't like seeing him wearing gloves while using a milling machine)
Cheers and good luck.
David.
Dawn
Active Member
Jun 4, 2018
37
David,
Thank you very much! Great information!
Yes, I saw that first video during a YT search and, yes it was very hard at times to understand, though still respectfully amusing. Second video was awesome..!
BFHammer
Jan 27, 2017
154
I did the same as Kiwi with positive result. As he mentioned - measure twice - order once. :grin:
[6]
[5] [7]
