- Apr 30, 2015
- 11,327
This is carrying over from Harry's conversation. We had just determined his control box is ok and the motor has a fault.
-Mark
-Mark
The cap is actually riveted on, I will have to cut the wires, I will take a pic.Let's see how your meter behaves when measuring a cap. It will be helpful later. Short the cap first with a screwdriver and then measure it with your meter on ohms.
You should see the reading start off low and start rising. When it seems to stabilize after a few seconds, reverse the test leads. Same thing should happen. Swap them again. Same thing. When you are getting a repeatable result, then wire the cap back on the motor. Now, do the same test only between the jumper straps and the Z1 terminal that had the red wire. Should get the same thing as measuring the cap as before. This tests the start leg.
I will come back out here after dinner, Like I said, I have no clue what I am doing so I know it sounds easy for you, But I need it spelled out pretty much.Ground screw? The jumper straps on the motor terminal block that are in a "L" configuration- that should connect to one meter lead. The other one to the terminal where the red wire was connected. You should get some low ohm reading like 5 to 10 ohms or so with the cap jumpered
