Sharpen an old screwdriver to a fine wedge shaped point and lightly hammer it under the back edge of the gear, then tap on the threaded end of the shaft with a soft hammer, then repeat, if one has two sharp screwdrivers or similar tool, use one on each side of the gear, 180 degrees apart. Should do the job.
