- Nov 19, 2011
- 966
hi guys, if you tinker with auto's like i do from time to time you find out you may need to turn a brake drum. what i did i had a old axel to my truck laying around so i cut it in two leaveing a 4 inch stub on the hub end then i chucked it in my lathe and centered it and turned my brake drum around backwards and mounted it to the hub then i was able to turn the drum. keeps you from paying to have someone else do it for you and you save money
