You will probably get more replies if you list the specific areas vs craftsman's letter system.Hello All,
I'm 100% sure this has been covered here, but I can not find it.
What types of oil should I use for locations A, B, C, D and E? What type for the ways? What type for the Timken bearings?
Thank you very much.
John
So #68 way oil even in the taper bearings?You will probably get more replies if you list the specific areas vs craftsman's letter system.
Off hand I would venture #68 would cover most of it.
I would think grease in the bearings.So #68 way oil even in the taper bearings?
If you have oil caps your lathe may have been converted from Babbitt bearings.
What is a "loss system"? What oil should be used in the cups for the timken bearings? Thank you.The spindle bearings are a loss system, oil is used in the cups
That's what I figured it meant. That's exactly what happens too. I put oil in the cups and it runs out of both sides. Too bad there's not a way to hold some of it in there. lol.Loss system means the oil runs slowly out of the bearings all over your booties
I believe 20 wt non-detergent oil is specified for the Timken bearings
