Typical Job In The Shop
Ray C
Nov 16, 2012
5,586
So, here's a typical kind of job I get. I've never done this particular modification before but this was a fun little knock-out that took a very short time to do. This is a boat component. The top one is a finished piece and the bottom unit is typical of what I was starting from. The original piece does not have enough lip or flange protrusion and it damages the hulls of the vessel over time. This is all 316 stainless so what I did was make rings of the customer-specified diameter and TIG them to the originals. The customer wanted a "sleek" profile so this is what I gave him.
Here's the TIG work. It has to be done in an argon flood tank and when doing the torch work, I made custom aluminum blocks to suck-up the heat. The plasma was hot and super-tiny pin-point and I move the rod in as fast as I can go. I keep a thermal gun and measure temperature and never let the part get above 250 F. I'm also using 316 filler rod. This way, the stainless does not transform and it will stay stable when immersed in sea water. If these things fail someone's $1,000,000.00 (not kidding, ONE MILLION) yacht will sink. -And this is why you carry insurance.
A close-up of the finished work. Although not shown, the weld cap is cleaned-up off the back side. This was one of 5 pieces and I also made custom backing washers for the ring nut. The little screw on the ring nut is a grounding terminal to prevent corrosion and also aid in providing an "Earth Ground" for the vessel's electrical system.
Ray
xalky
Jun 17, 2012
2,215
Nice little job. Looks like you found one of your little niches at the boat yard.
Rbeckett
Gold
Rest In Peace
Sep 24, 2010
3,095
Lookin good Ray!!!! and those will never fail on a glass boat since they have a good flange now... Congrats on finding a niche'
Bob
Ray C
Nov 16, 2012
5,586
Thanks for the nice words and encouragement guys...
Niche... well, kinda. I've picked-up quite a bit more work from different customers in the last week. -A couple are long term and mainly custom repair work but not in the boat world.
Some of it I can post and some I cannot. I'm going to talk to Tony and Nelson et.al to see if they're OK with me posting it. It's pretty much high-risk and needs inspections and insurance etc...
Ray
itsme_Bernie
Jan 11, 2013
1,748
Dang Ray, that is beautiful!
Are those threads ground?
Bernie
Ray C
Nov 16, 2012
5,586
Bernie
They all looked cut. Of all the fixtures I modified, some were brand new and some were original from the vessel. They put an adhesive on there to seal it up and if the adhesive gets in the threads, the fixture gets destroyed when removing them.
FYI: Here's the galley on one of the vessels I was working on... -Not too shabby...
Ray
Jamespvill
Feb 4, 2014
185
Fantastic looking piece. I need more jobs that require being TIG'd...I'm getting rusty and wasn't that good to start with. Those are some mangled threads on the original piece!
On a side note- Think of all the machining goodness and CNC fantasticness that 1 million could be spent on apposed to a yacht!
xalky
Jun 17, 2012
2,215
We need the million dollar yacht people to support us little people! It's all a part of the economic eco-system.....$$$ makes the world go around!:))
Marcel
itsme_Bernie
Jan 11, 2013
1,748
I've had less fancy gallies in my own apartments!
Shadowdog500
Apr 7, 2014
339
Looks really good. Is that going below the water line? I've used 5200 to seal stuff like that on my boats in the past and I agree that it is a pain to remove, but I bet the fiberglass would give before that stainless part does.
looks good!
Chris
Ray C
Nov 16, 2012
5,586
looks good!
Chris
Oh, that 5200 sealer is evil stuff. It's like a mix of Elmer's glue and super glue. If the 5200 gets in the threads, it's next to impossible to get the ring nut off. The spanner wrench that fits in the front doesn't give you enough leverage and if you put a pipe wrench on the shaft threads, that usually ends-up damaging them. I've seen these things completely smeared with 5200 and I reached immediately for the grinder to split the ring nut... Anyone that's ever worked on boats like this knows how little room there is to work and the luxury of a 14" wrench is not going to happen... For several weeks every spring, I do yacht repairs with a friend. -Oh those first couple days are killer.
Most of these overboard drains go above the waterline but on this vessel (which I didn't work on myself) I'm told there were several below the waterline. Seems weird to me but, I don't ask questions...
Ray
B
Bill Gruby
Forum Guest
Register Today
Looks like you have found your little nitche in life Ray. Very nice indeed.
"Billy G"
trukker
Feb 4, 2013
42
Nice, not sure I understand what it does! Is it for a bilge pump? Anyway does the temperature control reduce the temper color changes? Hope you get "permission" to share more!
Ray C
Nov 16, 2012
5,586
Hi...
I assume it was a bilge pump outlet. With stainless steel, color is changed by exposure to oxygen when the part is above about 500-600F. The hotter it gets, the darker it gets when exposed to oxygen. It will turn blue if it gets hot enough. When I do stuff like this, the work is set inside a small enclosure and I flood it with argon and use a larger size shielding cup. I also work as fast as I can. This displaces most of the oxygen and keeps the heat low. I could easily do that all in one step but you can see, I broke it up because the part was getting a little too hot. The heat doesn't bother stainless too much but I didn't want to oxidize/discolor the thread part as, some folks could mistakenly believe the part was heat damaged -which it is not.
As for posting pictures... My stance is to assume my clients want me to preserve their privacy. I take before/after pictures of every job I do and that's mainly to cover myself in the event of a dispute of some sort. My feeling is that I do this for money, every job is under contract -and that the customer owns all rights to the work (including photos) once the contract is signed and a commitment is made for payment.
Ray
Marco Bernardini
Dec 17, 2012
745
Ray, may I suggest to take videos, too?
Maybe with a clock in the background, just in case someone complains you charged too many hours for the job.
Generally common people don't have an idea of the time required to make a piece, specially if it requires a good precision.
The most of the people don't even know what a reamer is, unless they found it in the crosswords…
Ray C
Nov 16, 2012
5,586
Oh, I really don't like messing around with video files. They take way too long to transfer to the computer and I'd need a zillion terabytes of hard drive storage. I quote all prices up-front when/if I accept the job. I just had a multiple part order (100 pieces to start) for special fasteners for a local training academy. It was a small, custom fastener made of stainless steel and it had some unique characteristics. Each one had 6 operations and it was all manual work. Before accepting something like this, I insist on providing a first part for inspection and sign-off. When I make that first part, I time all the operations and that allows me to make accurate estimates. For simple non-quantity jobs, I'm pretty good at estimating times.
Also, most (but not all) customers don't really care what's involved in making a part -they just want it made or fixed.
Anyhow, taking pictures is mainly for my protection. If someone modifies something after I made it, I have proof. I someone claims I didn't make the right thing, I have proof... I always provide the pictures to the customer when they get the part. This tends to prevent problems before they start. Also, most of my regular customers are great to work with. I'm a subcontractor to them and the photos help them deal with their customers.
Ray
trukker
Feb 4, 2013
42
I get the concerns about using pictures of a customer project. I thought you meant the moderators would have some issue with posting it on the forum. Maybe sometimes both. Anyhow look forward to more!
Ray C
Nov 16, 2012
5,586
There are some concerns about both issues. I do a fair amount of critical part heat treating and don't want to plant ideas in people's heads that doing such things can or should be done in a home shop -especially without proper knowledge, procedure, equipment -and insurance.
Ray
AlanR
Dec 14, 2012
195
When I worked in a grinding shop we'd dip tools into muriatic acid to remove bluing. Does that not work for stainless?
Ray C
Nov 16, 2012
5,586
I don't know but it probably does. The staining is just a slight oxidizing from air/oxygen burning-off at the surface of the hot part. It buffs off easily. It takes an awful lot to cook and damage stainless steel. It's the predecessor material to Inconel (mainly chrome and nickel) which can take a tremendous amount of heat abuse. I've experimented with stainless by cooking it with the TIG unit. It goes from yellow, to brown, to blue, to dark grey and back to brown again. Once it hits that dark grey color, it's probably not to be trusted for anything important.
Ray
AdBlock Detected
I've Disabled AdBlock
