[4]
Un-square square lathe tool bit
[3]
[10] Like what you see?
C
cg285
Guest - Please Register!
#1
i don't know if anyone has run into this but while gearing up to make a shaper tool holder i went to test fit a 1/4" hss lathe bit into one of those commercially available round sleeves with a square hole. i could almost get a .257 pin ga though the sleeve and the bit meas .255. no way jose would that even start to go together. put it on the surface grinder and touched up 2 sides. it was obvious it was one of those parallelogram squares. (at this point you can hold it up to the light, when in the sleeve, and get a visual)
made in china but i didn't know that when i bought them from mcmaster. i don't know how anal i need to be but i was going to indicate the sleeve square with the holder. could be out a few thou differently every time a new bit is put in.. would be a *****, i assume, to perfectly square that 1/4" bit. don't know if there is another source that's better.
i guess i could spend a bunch of time getting something square to align it with but seems like an improper use of time.
edit: i guess the "B" word is not kosher here haha
Mitch Alsup
Active Member
Nov 17, 2017
352
Likes
235
#2
In a similar vein; I bought some hot rolled 1/2*3/4 mild steel. What arrived looked a lot like a 5/8 round bar that had been run through a flattening roller to end up at 1/2 thick in one dimension with most of the original radius as the other dimension--NOT even close to flat.
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
813
Likes
533
#3
Do you expect HR steel shapes to be even reasonably straight?
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
3,681
Likes
4,286
#4
In my experience, HR is seldom flat, let alone square. This is especially true for smaller sizes.
benmychree
John York
Jun 7, 2013
2,751
Likes
1,992
#5
I have had a lot of HR round through collets in the turret lathe for threading, most I have seen has been reasonably round.
mcostello
Dec 29, 2013
389
Likes
181
#6
Some tool bits are parallelograms used in screw machine tools.
C
cg285
#7
there it is haha. i was in LANKister once when i bought some gm tooling that Premix ran the parts at that time
[6]
[5] [7]
