- Jan 2, 2016
- 1,953
There is two types of unloader valves. The ones most are familiar with, unloads the pressure from the head, to the tank when the motor shuts off, making it easy to start up the next time. The other style, many big compressors have, unloads the head, when the pressure is reached, (Like what is used on gas driven compressors,) So the compressor stops pumping, but the motor can still run. Some setups will turn off the motor, and some leave it running (Do not know why, but I had one). Those look like the second style.
Yes, you can remove ort bypass the parts you are looking at. The unloading you want is the one that releases the air in the line from the compressor to the tank (assuming the is a one way valve at the tank).
