- Jun 12, 2014
- 4,818
The Z axis drive should be enclosed, so should not be a problem with chips. It could be that the motor is marginal and the additional viscosity of the stock grease is a problem. If using oil, I would use way oil, but that would be a short term solution and would need periodic reapplication. As previously mentioned, I would suggest air craft grease or a synthetic grease which are designed to work over a wider temperature range. You might also consider something like Mobil 1 synthetic grease or Super Lube synthetic with PTFE in a very thin layer. I have used synthetic gear oils in the head of mills and picked up some top end speed and worked better over a wide temperature range.
