- Apr 20, 2011
- 430
Using a file to sneak up on that final size is probably a personal choice, however its used by many.
My highly skilled machinist mentor/friend with some 50 yrs of experience probably uses a file on every piece he turns - a file and then finishing off with one of a dozen or so 1/2 - 3/4" strips of various grits of emery he has hanging just to the side of the lathe. As he puts it, "the only thing that will turn true - or at least close to it - is a CNC lathe" saying that while he has operated some very fine lathes that cut beautifully, they will all - at times - leave a bit of taper, or a high/low spot of so some varying thickness. And once youve run your lathe a while, it becomes glaringly evident that trying to turn .0015-.002 thou off to get that final dim can be a frustrating experience.
When Lane gets down to needing .002, or maybe even .003, he grabs a fine tooth file and quickly brings it within .0005 or so, and then the emery finishes it off. Often I find Im cutting some piece of "unknowium" (scrap yard stuff) over 3-4" and will get an irregular finish - striping? - and with out a file and emery the piece would likely be unuseable.
Its quite surprising what emery will take off also...
