Using three pin gauges to extend measurement range
By using two pins the check a hole you can nearly double the range.
You can extend the range slightly more by using three pins. The math gets more complicated but if you have CAD capability, the CAD math engine will solve it easily. If you use three pins differing by +/- .0001, the diameter is 2.1547 x the middle pin diameter.
yes, but holding 3 pins in line becomes a little more difficult. You can do it, but you need to use 2 bars, sticks whatever to keep them in line... if they triangle out on you, you lose your measurement.
It isn't three pins in line. They form a triangle. It is actually more stable than two pins as two pins have to be exactly parallel to each other to get an accurate measurement.
An added bonus is that three pins can extend the precision of the measurement. My pin sets all measure out at +.0002 or -.0002 from nominal, depending on whether a plus or minus set but the pins increase in .001" increments so the best I can do is to measure to within .001" However if I use three pins, two of which are slightly under the radius of the hole, a third pin will actually resolve to about a tenth. It requires some math to do this but my CAD program comes to the rescue for that.
Excellent, thank you guys! So now I want to figure out the math without the cad package and work out tables for the three pins (X-0.001, X, and X+0.001), let X run from 0.062 to 0.249. Now THAT would really expand the range. If it's too sparse a set, then we need the arbitrary solution for three diameters and the superscribed circle.
Fun!
