H
Hukshawn
Forum Guest
Register Today
Anyone ever made their own variable speed pulley? I have an idea for a power feed for my mill.
The legit power feed units (cheapest I've found was $400) are too expensive, so I'll make my own.
I have been poking around for a gear reduced motor unit to work with, found a very small power winch, almost cute.
https://www.princessauto.com/en/detail/220-440-lb-electric-cable-hoist/A-p8041840e
Like that one, but 110-220 lbs and only $99. The whole unit is about the size of my forearm. The motor is 6" long, maybe. The motor is the motor and gear drive in one small package. Perfect. I could easily strip it down, put a chain cog on it, mount it on the mill table, and bobs your uncle. However, I was variable speed. I was thinking about a variable speed pulley drive. Turn a hand crank and change the speed. Small parts, small pulleys, small belt, all in a little package.
Question, how well do you think a variable speed pulley would operate at, say, 20 rpm...
in my mind, it shouldn't be a problem, as the pulley is forced apart by the hand crank and not centrifugal force. So, it really should work at any speed.... no?
