- Jun 15, 2017
- 535
I am making my shop larger by organizing and cleaning it. I think it's time to make shelves.
When I moved here, this shop had a huge 4-tier shelf unit made from whole plywood sheets and two-by lumber. I don't like it. When the long side was against the wall, I couldn't reach anything next to the wall. Now that the short side is against the wall, it sticks out 8 feet into the shop.
I am thinking of stealing Jamie Hyneman's idea. He built shelves using 1"-square steel tubing. It welds together in a hurry, and it's very strong. To make one unit, I would screw several tubes to the wall horizontally and use horizontal members to join them to vertical tubes about 18" out into the shop. Then I would add plywood.
Here's a question: what's the best vertical distance between shop shelves? I would guess my current shelves are two feet apart, and that's too much. Most of the space is wasted. I am thinking 15" or 18" would be best. If I need more, I can make a second unit with different spacing.
I know it's impossible to give sure advice without knowing what I'll put on the shelves, but this is your typical home shop with typical junk. A few electric motors. Tool boxes. Cans of solvents. Paint. I'm not planning to put a lot of tall items on them.
The only thing I don't like about his shelves is the lack of paint. I have to have paint. I don't want black mill dust and rust to get on me every time I touch a shelf. I think I'll paint them before welding, except for the areas where I plan to weld. Then once they're installed, I can touch up the bare areas.
Hyneman Shop Shelves
