- Oct 11, 2016
- 3,866
@Dabbler, the Teco derating for the carrier frequency applies to the VFD, not the motor.
@rabler I'm sorry that I didn't notice we were talking about two different things.
The thing you need to know is that the duty cycle of the mill is lowered.
When using the motor off 60 cycles you reduce the efficiency of the whole system. The efficiency loss will have 2 consequences: reduced torque and increased heating. When using it near 60 cycles, the effect is not noticeable. If you use it at the extreme ends of the spectrum, at 10 Hz and 110 Hz for instance the losses are pretty large and you have to be careful. By reducing the duty cycle, or your torque expectation, you can still use a non-inverter motor quite nicely at those resultant speeds.
This is the 'derating' I was referring to.
