- Jun 12, 2014
- 4,822
The motor needs to be directly wired for the voltage you are using, so it would need to be set at 230VAC as the VFD is a 200-240VAC model. The VFD should be directly wired to the VFD motor inputs. Due to the nature of the PWM output, I do not believe an amp clamp will give an accurate reading, but almost all VFD's have the ability to display output volts/amps. The VFD will not go into current protection mode, as it is only outputting what it is set to deliver, as the VFD , as the VFD output is rated at 3/4 Hp.Does the motor need to be wired differently for 230 vs 460? This is the first dual voltage motor I've played with so I'm new to this stuff. Using an amp clamp the amp draw continues to rise while the RPM goes down, but the VFD doesn't go into current protection.
Would I be fine setting an upper limit restriction on the VFD and just dealing with the lower power output from the motor? For my purposes I'll likely never need all 1HP out of it.
There are many factors to output Hp, and this only holds at the motor base speed of 60Hz. Below that speed the Hp falls off and torque may stay flat down to 20-30 Hz, but you loose the mechanical advantage. So you have gone from a 6 speed head to a single speed head, with only a 1 Hp motor with a 3/4Hp VFD , the performance will be very anemic over most of the operating range. At say 30 Hz you would be generating maybe 1/3 Hp and also loose the mechanical advantage of 2 for the loss of the belt ratio. If you look at single speed variants of mills with a back gear of this type you would use a 3-5 Hp inverter/vector motor run from 20-200 Hz to cover 500-5000 RPM and a back gear to cover 50-500 RPM.
