- Jan 14, 2013
- 62
If you can't get the switch from Home Depot, go to hardware store or Radio Shack or a parts house like that and get a double pole switch rated for whatever amperage that your breaker is. If it is a 15 amp double pole, get a switch rated for 15 amps 220VAC, if it is a 20 amp breaker, switch needs to be rated for 20 amps 220VAC. You can get a blank cover plate in plastic or metal and bore holes to mount to box (screw holes top and bottom), Then drill appropriate hole to mach barrel of switch. You only need a toggle switch. I have made switch plates and switches for various projects this way. Just remember, the ground is not cut and does not go thru the switch. only each breaker has a line connected to the switch (one for each side if it is 220V 1 Phase). From the other side of the switch connect it to the load or receptacle. That way, you won't have to pay $$ for a $ switch. Most switches are rated for AC or DC, so get an AC rated switch. Most are universal.
The switch I bought I got on ebay its a 30 amp industrial 220 switch. I may just go with the fuse disconnect because it has a throw switch and I can use the throw switch for the off/on.
