- Jun 12, 2014
- 4,818
The manual is very basic, if you take a picture of the motors, I can give you recommended parameters. It can be run off of a 20A breaker, I assume the motors are 2 Hp or less. If the purpose is to just show that the mill/lathe run there may be some work around as to direct wiring to the motor, but only to show that the motors work. Depends on if there are any transformers or contactors in the control circuit.
