- Jun 12, 2014
- 4,828
MF.K is a multi-function key/sequence. Try pressing both the PRG +enter together. Have no idea what 001.32 means, it is not an error code. To get to the functional code in the programming mode you need to hit the PRG/ESC button followed by the down key for each lower level and enter key to access that level, then the up down keys to select the value, then hit enter for it to accept the change. Hitting the PRG/EXC does not save the parameter but brings you back one menu level. You might also call or email the dealer you bought the VFD from. I have not used this brand, so without hands on it is hard to evaluate how it works.
