Well, I am finally back with a bit more done on the lathe. The parts came in from Maine with no damage and they will help immensely as I go along.
I was able to get the base completed, after making an adapter plate for the motor, and then making the v-belt adjusting mechanism from scratch, as the original was missing. I also had to press out the crankshaft from the crank bushing for the cone belt tension arm, as it was frozen solid. After pressing it out, I polished it in the lathe and put it back together with good results.
Then I reassembled the base, bed, legs and chip pan...
There is just a hint left of the original scraping on the ways....
I am thinking that this lathe sat out in the elements for quite some time, as everything I go to take apart is rusted together, and the ways are slightly pitted in places. Just trying to take the tail stock apart was a bear, with the side adjusting bolts frozen in place. It took nearly a week of heat and penetrating oil to finally take the two halves apart.
I decided to make two new adjustment bolts, as the old ones were very rusty and mashed up.
When I checked the pitch on the originals, I found that they were 5/8" x 12 tpi. I didn't have any all thread that size ( Isn't this an odd thread pitch for 5/8" ? ), so I decided to thread my own from some 3/4" ground rod. I didn't have anything to check the thread size as I went along, and there was no way to try the thread in the tail stock until I was done.
I haven't done much threading before, so I looked up the thread depth value in my Machinery's Handbook and used thread wires and a micrometer to get to the thread depth. Then I parted the two pieces, turned down one end each, and slotted them. After running a 12 tpi tap through the tail stock, I tried the bolts.... I was amazed that they fit perfectly, with no slop, but not tight. I guess that I got lucky
I found these .009" brass shims between the halves of the tail stock...
I now have the tailstock back together and on the lathe, with everything working nice and smooth.
I will tackle the headstock next.
Brian
