- Aug 3, 2017
- 2,437
About 6 months ago, I was installing a plug for my wife's EV charger that sits outdoors. The charger itself is outdoor rated, and is NEMA14-50.
SO, I bought this enclosure: https://www.amazon.com/gp/product/B08549S8KK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I mounted it about 8 feet in the air off the side of my shop, and wired out the bottom with the big plastic conduit material. It comes straight down about 2 feet, and uses a 90 degree conduit elbow to go through the metal wall of my shop, and directly into a junction box, where I used the Polaris connectors tied everything together (6 gauge wire, so wire nuts were out). I used a TON of silicon sealant on both the inside and outside of the conduit where it entered the building.
Today was our first big rain of the season, and when we went to plug the car in, the light didn't come on! I went into the shop and saw the breaker trip, so flipped it back, just for it to instantly break and release magic smoke from my junction box.
I pulled it apart, and it was pretty fried up, the rubber/plastic on the Polaris connectors (like this: https://www.homedepot.com/p/Polaris...-0B/303578434?source=shoppingads&locale=en-US) were straight charcoal!
It was 'damp' inside the box, so my only theory is that sufficient water got into the box to short something enough to cause catastrophic failure. I'd like to fix it/redo the work in a way that can survive a storm next time!
I pulled the box apart to check for where water could have gotten in. The metal wall of the shop is bone dry, and the silicon sealant around the conduit is perfectly in tact and water tight.
My only guesses are either:
1-condensation: The shop is insulated, but not THAT well? I sometimes get some condensation on machines, but I can't imagine it would have been THAT much to short a significant distance for those connectors.
2- Water got into the conduit through the top, and just poured in. It is still raining NOW, but I didn't see any obvious water coming in now, though I don't know what could have happened otherwise.
So my questions are: Did I do something stupid with the install? Should I have put some sort of sealant inside the conduit to prevent water from getting in/out? How do I prevent this from happening again?
