[4]
Water Proof Shaft Seal
[3]
[10] Like what you see?
lellasone
Newbie
Jan 4, 2017
15
Hi All,
I was wondering if anyone has some good resources (or thoughts) on how to seal a small spinning shaft. My current thought is to try to make a small stuffing box with an 1/8" layer of grease between two sealed ball bearings, but since I've never done anything like this I figured I'd reach out and see if that's reasonable.
All the best,
Jake
lellasone
Newbie
Jan 4, 2017
15
Can't believe I forgot to say what I was sealing against, in this case water. Less than a meter deep, but it's got to run submerged.
Thanks for the replies. It didn't even occur to me to check Micmaster, but of course they have something for exactly this.
I'll take a look at that PDF.
extropic
Nov 24, 2014
550
What horse power is involved? More precisely, how much friction can you handle from the seal?
Shaft diameter?
RPM?
magicniner
H-M Supporter - Silver Member
Oct 21, 2017
478
Mechanical Seal.
It's what they use on automotive water pumps, commonly a Viton seal running against a ceramic surface.
Downunder Bob
Staff member
H-M Platinum Supporter ($50)
May 16, 2016
1,079
Hi All,
All the best,
Jake
For a proper response we need to know more about the application, shaft size, rpm, hp, salt water/ fresh water,depth of water or head, duty cycle,
tq60
Brass
Jan 11, 2014
740
If running underwater the seal can be of many options that are dependent on rpm and pressure...but forget about the seal for a moment.
Material selection more important now as different materials act differently dependent on chemistry.
Once all of the materials are determined next is fit and bearings as the shaft needs to run true and not have much end play.
Last then is determining what style of seal that will meet the rpm needs and fit in the part.
David S
Nov 18, 2012
1,327
I am not sure what you are trying to make / do, however you could buy one of the very inexpensive small submersible boat bilge pumps and see what they do.
David
Downunder Bob
Staff member
May 16, 2016
1,079
David
Some of these small pumps use a magnetic drive so there is no shaft to seal, not sure if that's option this case.
Cobra
Apr 24, 2013
681
All of the bilge pumps for small boats I have seen sit in the bilge with a float switch and pump to an outlet above the water line.
Shootymacshootface
Active Member
Mar 17, 2018
341
Outboard motors use 2 oil seals installed back to back , one to keep oil in and one to keep water out. It is simple cheap and it works.
epanzella
Apr 8, 2013
916
Just look up the prop shaft seals on outboard engines. They're cheap and are designed to do just what you're doing.
Downwindtracker2
Sep 5, 2014
411
On my old small blue band Mercs, they are single seals but of a deeper ,more robust construction. I thought of using commonly available ones but went with the proper ones.
[6]
[5] [7]
