All of the above, also make sure you cut the wire at the contact tip before each start. I like to bend the wire at the contact tip, place the wire against a gloved hand pull the trigger and the drive rolls should be tight enough to coil the wire against the hand with .030/.035 hard wire. If not you have one of the problems listed above, process of eliminanation.
........Just work getting in the way of hobby stuff.
GOOD ADVICEAll of the above, also make sure you cut the wire at the contact tip before each start. I like to bend the wire at the contact tip, place the wire against a gloved hand pull the trigger and the drive rolls should be tight enough to coil the wire against the hand with .030/.035 hard wire. If not you have one of the problems listed above, process of eliminanation.
