- Dec 30, 2018
- 73
I am busy upgrading my mini mill - part of which involved welding a structure from 10mm steel plates.
The base plate is about 12" by 25" and is 10mm thick.
I decided to add a couple of steel bars to the bottom of the base plate for additional support.
After welding, I discovered that the whole plate has been bent out of shape along both it's width and length.
I knew that stuff will bend while it is welded, but did not think this will happen on 10mm steel.....
Fortunately I did manage to get it bent back to within about 95% of what it was.
