- Sep 8, 2019
- 4,392
me too.30 degrees for threading, except for Acme threads @14 1/2 deg. I never bought into the 29/29-1/2 deg. thing, was taught in high school by an excellent teacher to use 30 deg and every journeyman that I came in contact with did the same. As stated by others, 90 deg interferes with the tailstock on most lathes, and zero setting can interfere with the cross-slide crank and visibility of the cross-feed dial.
Ditto, If I've been trying to pickup a tread it will be parallel to the spindle. If I was making a long chamfer it will be at 45 or it will be at any other angle that was useful. I don't use the compound for threading, just straight in.Whatever angle it was last used at.
Thank you Frank, Its a Colchester Chipmaster, I have added tee slots to the cross slide and and made the topslide which can be moved and locked by the side lever.Used to use 90 but it was awkward with the tailstock sometimes so I shifted to 29 degrees and it’s stayed there ever since.
@jackary99 that’s a nice looking machine and top slide — what is it?
-frank
Yes @jackary99 that looks much fancier than most of us mortals deserve- care to enlighten us?
Especially interested in your toolpost
-Mark
Could you share more details? Beautiful work!!Hi Mark,.
The toolpost is my version of the MLA toolpost, I have only made two toolhoders but that seems to be ok. The idea was to minimise cantilevered overhang and keep the cutting forces over the cross slide.
Alan
