[4]
What are these used for?
[3]
[10] Like what you see?
Barncat
H-M Supporter - Silver Member
May 14, 2018
81
Likes
39
#1
These were in an auction lot of machining parts and pieces. I tried looking around on Google, but don't even know what to call the to try and look them up. IMG_20180523_163025483_LL.jpg
BROCKWOOD
H-M Supporter - Gold Member
May 26, 2017
478
Likes
288
#2
The rule on the edge blows my theory. I dunno. Oh, my theory? Book ends in a public library. Probably from the 50s at any rate.
34_40
Dazed and Confused
Nov 2, 2013
756
Likes
232
#3
I was thinking maybe it goes on a vertical band saw?
brino
Jan 2, 2014
3,461
Likes
3,487
#4
I dunno......
Are the gaps different sizes? It looks like they are.
They may be some sort of gauges.....for what I do not know.
-brino
Bob Korves
H-M Platinum Supporter ($50)
Jul 2, 2014
6,051
Likes
6,377
#5
In the photos they appear to be of different thicknesses, shims perhaps, but the scale on one of them leaves me not even guessing...
Barncat
May 14, 2018
81
Likes
39
#6
They are of different thicknesses. Some steel, some aluminum
12bolts
Global Moderator
Apr 23, 2011
1,967
Likes
432
#7
They are for calculating shim thickness when aligning connections. Such as a motor to a pump. Used similar to feeler gauges, stack them together and fit them under the base. Held/manouvered by the apex of the triangle. The slot is to get around the mounting stud/s Ruler is to give you an idea of the size of the required shim, and also where the required stud holes/slots will need to be drilled.
Cheers Phil
Barncat
May 14, 2018
81
Likes
39
#8
Cheers Phil
Thanks! I knew this was the right place to ask
[6]
[5] [7]
