- Aug 23, 2014
- 932
Here is one with a 5/16" holder for $29.95:
This one is $24.95:
I'm assuming you have a QCTP? you can use up to 1/2" holder with a 0XA QCTP. The original tool post on a minilathe is made for 5/16". I'm suggesting not buying the more expensive ones since you will most likely want to make your own when you have the equipment.
These should do what you want and give a decent knurl.
Roy
Spring Loaded Clamp Type Knurling Tool 2" Inches Capacity 5/16" Shank for Lathes - - Amazon.com
www.amazon.com
This one is $24.95:
2" Capacity Knurling Tool 5/16" - 8mm Shank to Hold in Quick Change Tool Post - - Amazon.com
www.amazon.com
Roy
