What is this chuck mount called?
skogkatt007
Nov 26, 2023
226
I realize no one has the lathe in front of them. In the referenced thread for my Central Machinery 8.5" x 18" (a lie) geared head lathe, you'll see a photo or partial photo of the chuck plate. I don't know how to identify it.
It came with a stock 4" 3 jaw. I would like to add a 5" 4 jaw independent. Like this
Do I need an adapter?
6" is nicer
Most new chucks require a mounting plate specific to your lathe. The 6" says this specifically, but the 4" is silent on the matter. I would say that since it doesn't say what lathe that it fits, you will need a mounting plate.
Figure on machining the back plate to fit the chuck. It's not difficult. Just mount the back plate to the lathe and turn the face of it to match the back of the chuck. You want a close fit so they will go back together the same each time you take them apart for cleaning and lubricating the internals of the chuck.
I think you have what's called a flange mount- Little Machine Shop has adapters I believe in that style
Some machining may still be necessary
Just did that a 5" 4 jaw .
I choose a 5" it hurts less if I drop it on hand. I plan on making a 7½ face plate too.
The backing plate came from little machine shop.
I made this adapter close to 30 years ago for a new 5" three jaw but I can't remember how I did it. The flange had to be modified to allow for the three mounting bolts of the new chuck. I still use that lathe some to this today.
Ray
